SkyConnect will nicht mehr :-)
Hoddl
Beitrag von Hoddl »
Seit heute will der SkyConnect nicht mehr so wie ich wohl will :-)
hier das Protokoll - hat jemand eine Ahnung was los ist kann mir vielleicht helfen?
Logger: homeassistant.config_entries
Source: components/zha/core/gateway.py:205
First occurred: 15:59:24 (1 occurrences)
Last logged: 15:59:24
Error setting up entry SkyConnect v1.0, s/n: d6b24552f8d4ec118f1a1db1a1ca919a - Nabu Casa for zha
  File "/usr/local/lib/python3.10/site-packages/bellows/uart.py", line 268, in reset
    return await self._reset_future
asyncio.exceptions.CancelledError
During handling of the above exception, another exception occurred:
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 387, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 122, in async_setup_entry
    await zha_gateway.async_initialize()
  File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 220, in async_initialize
    raise exc
  File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 205, in async_initialize
    self.application_controller = await app_controller_cls.new(
  File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 219, in new
    await app.startup(auto_form=auto_form)
  File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 193, in startup
    await self.connect()
  File "/usr/local/lib/python3.10/site-packages/bellows/zigbee/application.py", line 131, in connect
    self._ezsp = await bellows.ezsp.EZSP.initialize(self.config)
  File "/usr/local/lib/python3.10/site-packages/bellows/ezsp/__init__.py", line 150, in initialize
    await ezsp._startup_reset()
  File "/usr/local/lib/python3.10/site-packages/bellows/ezsp/__init__.py", line 141, in _startup_reset
    await self.reset()
  File "/usr/local/lib/python3.10/site-packages/bellows/ezsp/__init__.py", line 170, in reset
    await self._gw.reset()
  File "/usr/local/lib/python3.10/site-packages/bellows/uart.py", line 267, in reset
    async with asyncio_timeout(RESET_TIMEOUT):
  File "/usr/local/lib/python3.10/site-packages/async_timeout/__init__.py", line 129, in __aexit__
    self._do_exit(exc_type)
  File "/usr/local/lib/python3.10/site-packages/async_timeout/__init__.py", line 212, in _do_exit
    raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
Re: SkyConnect will nicht mehr :-)
Welche HA Version hast Du den aktuell am Start?
Was hast Du am System verändert, was eventuell den Fehler verursachen kann?
Schon mal in aller Ruhe HA neu gestartet?
@Hoddl Hast Du Multiprotocol https://skyconnect.home-assistant.io/pr ... iprotocol/ aktiviert? Falls ja schalt das mal aus bzw. lass es weg. Und bei Änderungen immer daran denken auch den Host neu zu starten. Ich meine in letzter Zeit mal etwas gelesen zu haben das es mit Multiprotocol zu dem von Dir genannten Fehler kommen kann.
Hoddl
Beitrag von Hoddl »
die neueste Version ist drauf es stehen auch keine Updates aus.
Neustart und auch mal alles vom Strom genommen hab ich schon alles probiert...
und jetzt steht folgendes im Protkoll:
Source: config_entries.py:1247
First occurred: 16:48:51 (1 occurrences)
Last logged: 16:48:51
Config entry 'Home Assistant SkyConnect' for homeassistant_sky_connect integration not ready yet; Retrying in background
Hoddl
Beitrag von Hoddl »
Jim_OS hat geschrieben: ↑Do 15. Jun 2023, 17:56
werde ich gleich mal testen...
Hoddl
Beitrag von Hoddl »
Jim_OS hat geschrieben: ↑Do 15. Jun 2023, 18:58
https://skyconnect.home-assistant.io/pr ... iprotocol/ :)
kurze zwischen info... bin noch am testen und machen bis jetzt geht nur der stick wieder... also er wird wieder erkannt nur die plugs udn birnen sind nicht aktiv... evtl. muss ich die wohl löschen und neu anlernen....
Hoddl
Beitrag von Hoddl »
der stick wird wieder als normal angezeigt nur kein einziges gerät ist am Stick verfügbar alle stehen auf "nicht verfügbar"
ich versuche nun mal die Abstellkammer als neues Gerät (Birne von Ikea) anzulernen
Also ich nutze weden den SkyConnect noch ZHA, aber bei den Diskussionen zu dem Thema Multiprotocol, an die ich mich erinnern kann, war auch irgendwie die Rede davon das es nach dem rückgangig machen zu Verbindungsproblemen gekommen ist. Worum es dabei aber genau ging weiß ich jetzt auch nicht mehr. Das scheint alles nicht ganz so einfach zu sein.
Im Normalfall ist es ja so das Zigbee Geräte selbständig gefunden werden und sich selbständig anmelden. So kenne ich das zumindest von meinem Sonoff Zigbee Stick und Zigbee2MQTT. Wie das dann bei der Kombination SkyConnect + ZHA aussieht, wenn man dieses Multiprotocol rückgängig gemacht hat, weiß ich auch nicht.
Hoddl
Beitrag von Hoddl »
ich denke ich werde erst mal auf Conbee stick zurückgreifen... bekomme einfach nix mehr hin... nix geht mehr :-( kann nicht mal ein Gerät hinzufügen...
Ich hatte das beim experimentieren auch 2 mal, allerdings mit dem Sonoff Stick. Wenn ich mich recht erinnere hatten sich die Gerätepfade nach einem Neustart nach Updates verändert/vertauscht.
Hast du dazu keinen Log der irgendeinen Fehler ausspuckt?
Hoddl
Beitrag von Hoddl »
hier ein protokoll was ich vom sky habe:
es ist echt frustrierend :-(
First occurred: 19:17:00 (4 occurrences)
Last logged: 23:12:09
File "/usr/src/homeassistant/homeassistant/components/zha/init.py", line 122, in async_setup_entry
raise exc
File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 219, in new
File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 193, in startup
File "/usr/local/lib/python3.11/site-packages/bellows/zigbee/application.py", line 131, in connect
self.ezsp = await bellows.ezsp.EZSP.initialize(self.config)
File "/usr/local/lib/python3.11/site-packages/bellows/ezsp/init.py", line 150, in initialize
await ezsp.
startup_reset()
File "/usr/local/lib/python3.11/site-packages/bellows/ezsp/init.py", line 141, in startup_reset
await self.reset()
File "/usr/local/lib/python3.11/site-packages/bellows/ezsp/init.py", line 170, in reset
await self.
gw.reset()
TimeoutError
Hoddl
Beitrag von Hoddl »
alles noch mal von vorne gemacht... nun dieses Problem:
ich verstehe es einfach nicht mehr...
Schau mal unter:
Einstellungen > System > Hardware > gesamte Hardware
Und suche dort über die Suchfunktion dein Sky Stick. Dort siehst du ob er wirklich ‚ttyUSB0‘ ist.
Verwende bei der Adressierung von USB Sticks nicht
dev/tty...
Diese kann sich mit jedem Host reboot ändern!
Sondern die
/dev/serial/by-id/......
Die serial/by-id ist unique und bleibt unverändert, egal am welchem USB Port Du den Stick einsteckst.
Diese findest Du unter: EINSTELLUNGEN -> SYSTEM -> HARDWARE -> GESAMTE HARDWARE
OSORKON
@Hoddl Lies Dir das hier mal durch: https://community.home-assistant.io/t/s ... xed/536867
Der User scheint wohl auch das Problem mit dem Multiprotocol gehabt zu haben und konnte es durch flashen der Firmware lösen.
FIXED: After reading more I used the steps on the SkyConnect Firmware update page:
Appearently I bricked my SkyConnect with the Multiprotocoll setting. The firmware update solved the issue. After firmware update (via windows) I plugged it back in my PI4 (ignoring the ZHA setup), restoring my latest working backup in HA, restarting my Pi and It was running as before recognizing all my devices.
Hoddl
Beitrag von Hoddl »
Osorkon hat geschrieben: ↑Sa 17. Jun 2023, 10:08
dev/tty...
Sondern die
OSORKON
bei mir ist der SkyConnect so in der Hardware drinnen:
Hoddl
Beitrag von Hoddl »
Jim_OS hat geschrieben: ↑Sa 17. Jun 2023, 11:23
das werde ich jetzt mal angehen... hoffe es bringt was.. ich werde berichten :-)
Hoddl
Beitrag von Hoddl »
das mit dem WebFlasher bekomme ich nicht hin... :-(
Hoddl
Beitrag von Hoddl »
das mit der id hat auch nicht geklappt :-(
Ohne Titel.jpg (131.19 KiB) 11281 mal betrachtet
Firmware gibt es ja z.B. hier: https://github.com/NabuCasa/silabs-firmware und dann entweder manuell flashen
https://github.com/NabuCasa/silabs-firm ... e-manually
oder per Browser: https://skyconnect.home-assistant.io/firmware-update/
Video für das flashen per Browser: https://www.youtube.com/watch?v=-88K23e8XYw
Sobald der SkyConnect bei dem per Browser flashen ausgewählt wurde und verbunden ist scheint man auch eine beliebige Firmware flashen zu können.
Sieht für mich jetzt nicht so kompliziert aus, aber ich habe das bei einem SkyConnect ja auch noch nie gemacht und weiß daher nicht welche "Fallstricke" es dabei geben kann. :)
Hoddl
Beitrag von Hoddl »
also ich habe mal den stick abgezogen... den pi komplett vom strom genommen...
dann alles wieder eingesteckt (ich glaube der PI war bestimmt 15min ohne Strom) hochgefahren...
das flash addon installiert.... alles noch mal geflasht....
dann die zigbee home automation aufgerufen und gesagt aus automatischen backup wieder herstellen...
das ging dann erst mal... alles war wieder da nur ohne Funktion..
ich habe dann einfach alle noch mal angelernt und sie gehen wieder auch die automationen...
danke an alle die so viel Geduld mit mir hatten :-)
Ach ja das Flashen kann a bissl dauern... auch wenn der rechte obere knopf schon wieder rot ist... habe im Protokoll geschaut bis es wirklich durch war...
Hoddl
Beitrag von Hoddl »
nachtrag... es reicht wenn man die Geräte wieder richtig benennt das alles wieder geht!!!!
